2019-01-15 22:47:26 ERROR (MainThread) [homeassistant.core] Error executing service <ServiceCall light.turn_on (c:8348f723ca3b445484daa1d60f081e0a): entity_id=['light.den']>
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/core.py", line 1177, in _event_to_service_call
await service_handler.func(service_call)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/light/__init__.py", line 355, in async_handle_light_on_service
await light.async_turn_on(**pars)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/light/hue.py", line 355, in async_turn_on
await self.light.set_state(**command)
File "/srv/homeassistant/lib/python3.5/site-packages/aiohue/lights.py", line 75, in set_state
json=data)
File "/srv/homeassistant/lib/python3.5/site-packages/aiohue/bridge.py", line 64, in request
data = await res.json()
File "/srv/homeassistant/lib/python3.5/site-packages/aiohttp/client_reqrep.py", line 947, in json
return loads(stripped.decode(encoding))
File "/usr/lib/python3.5/json/__init__.py", line 319, in loads
return _default_decoder.decode(s)
File "/usr/lib/python3.5/json/decoder.py", line 339, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/lib/python3.5/json/decoder.py", line 357, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 79 (char 78)
2019-01-15 22:47:52 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/lib/python3.5/asyncio/tasks.py", line 239, in _step
result = coro.send(None)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/service.py", line 224, in _handle_service_platform_call
await getattr(entity, func)(**data)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/light/hue.py", line 378, in async_turn_off
json=data)
Restarted HA and triggered the event. Nothing specifically points to it. I can manually turn on the lights through HA.
