Automation not working anymore after 0.92.2 - SOLVED
I have this automation:
- alias: Nessuno a Casa Spengo Radio
    - platform: state
      entity_id: device_tracker.life360_maurizio_fabiani
      to: 'not_home'
  condition:
    condition: or
    conditions:
    - condition: state
      entity_id: input_boolean.radio_play
      state: 'on'
    - condition: state
      entity_id: media_player.salotto_audio
      state: 'playing'
    - service: script.turn_on
      entity_id: script.radio_stop
    - delay: 00:00:02
    - service: notify.telegram
        message: Spengo la Radio.
It was working good everytime it was triggered since i upgraded to 0.92.2.
Now it is not anymore triggered when i am not_home. What is changed in 0.92.2 regarding this?
P.S. The script radio_stop is working good when called manually…
Take a look in Dev Tools/states if the automation is enabled (on).
Yes, it is enabled by default
@maurizio53
Try - delay: ‘00:00:02’ (quote around the time section)
Look on Script Syntax page under delay, this might be the issue. What does the log say?
instead of quoting, changing to:
- delay:
    seconds: 2
might help.
The script syntax page says the delay time should be in single quotes.
The log says nothing… Now i disable the delay action (really useless) and see what happens…
EDIT: Yes, now it works… So i must think the delay action syntax changed after 0.92.2 as before i had the automation working also with that action…
