I have the following automation to do a few actions:
- Lights (hal beneden / boven) on when it is between 07:45 and 23:15 when daylight level is below 8lx for 5 min.
- Then when the doorbell is pressed (detected) lights in hal beneden for 3 minutes to 100% when lights are on / illuminance level below 8
- lights off at 23:15
- when between 23:15 and 07:45 lights on for 3 minutes when motion is detected.
I most likely make an error in my thinking somewhere as it is not working as I expect.
When the doorbell is rang (detected) light do not go to 100%.
Lights also do not switch on when light level is below 8.
Would there be someone so kind to point me in the right direction?
Thank you very much.
Bernard
alias: Hal - Dynamic Lighting with Time and Motion - NEW
description: >-
Controls lights based on time, illuminance, and motion, with varying
behaviors.
triggers:
- entity_id:
- binary_sensor.voordeur_rzw33_doorbell
trigger: state
to: "on"
- at: "07:45"
trigger: time
- at: "23:15"
trigger: time
- entity_id: >-
sensor.hal_bewegingssenor_hal_boven_hal_bewegingssenor_hal_boven_illuminance
below: 7
for:
hours: 0
minutes: 5
seconds: 0
trigger: numeric_state
- entity_id: >-
above: 6
for:
minutes: 5
- entity_id: >-
binary_sensor.hal_bewegingssenor_hal_boven_hal_bewegingssenor_hal_boven_motion_sensor_status
to: "on"
trigger: state
conditions: []
actions:
- choose:
- conditions:
- condition: time
after: "07:45"
before: "23:15"
sequence:
- choose:
- conditions:
- condition: state
entity_id: binary_sensor.voordeur_rzw33_doorbell
state: "on"
- condition: numeric_state
entity_id: >-
below: 8
- condition: state
entity_id: >-
light.hal_verlichting_hal_beneden_hal_verlichting_hal_beneden_dimmer_1
state: "on"
sequence:
- data:
message: Doorbell pressed - Trigger fired
level: info
action: system_log.write
- data:
message: "Time condition met: {{ now().strftime('%H:%M') }}"
level: info
- data:
brightness_pct: 100
entity_id: >-
action: light.turn_on
- delay:
minutes: 3
- data:
brightness_pct: 20
entity_id: >-
- conditions:
entity_id: >-
below: 8
sequence:
- data:
brightness_pct: 20
entity_id:
light.verlichting_hal_boven_hal_verlichting_hal_boven_dimmer_1
- conditions:
entity_id: >-
above: 8
sequence:
- target:
entity_id:
action: light.turn_off
data: {}
- conditions:
- condition: time
after: "23:15"
before: "07:45"
- condition: state
entity_id: >-
state: "on"
sequence:
- data:
brightness_pct: 10
entity_id:
- light.verlichting_hal_boven_hal_verlichting_hal_boven_dimmer_1
- delay:
minutes: 3
- target:
entity_id:
data: {}
- conditions:
- condition: time
after: "23:15"
sequence:
- target:
entity_id:
data: {}
mode: single
