Automation not working - not invoking action even if variable is ok
I’m quite a newbie to HA so, maybe, is a trivial question… but I got stuck.
I have a thermostat and I can read the heating %
I’ve created an automation quite simple.
Calorifero Studio is the device I can read. The data I’m interested is Heating
What I’ve done on the Automation (on the right of the image) is that if the heating % is above 1% it should put the switch On.
Not I’ve tested the actions (Run Action) and is ok.
The issue is that even if the Heating percentage is 18% and moves from 18% to 29% the action is not triggered.
What am I missing?
I’m doing everything via UI
Leaving aside the odd units of %, if you are using a numeric state trigger “above: 1” it will only trigger when crossing from below 1 to above 1.
Understood!
Thank you.
Is there any way to define the condition “if above” not “if crossing”
