Hi, first thanks for a great software!
I have installed HA on ubuntu 20.04, not as VM/OS.
Then debmatic CCU for Homematic IP radiator valves HmIP-eTRV-2.
My problem is that automation is not triggered right, i.e. it triggers sometimes.
I want to my automation turn on/off switch (heating pump) based on current temperature, but it doesn’t always.
- automation - pump off based on temperature
platform: numeric_state
entity_id: climate.elternzimmer
attribute: current_temperature
above: '22.0'
below: '30.0'
condition - heating only during night in bedroom:
condition: time
after: '18:00:00'
before: '09:00:00'
- action
service: switch.turn_off
data: {}
entity_id: switch.sonoff_10005b5bca_2
- automation - pump onbased on temperature
above: '15.0'
below: '22.0'
condition:
condition: time
after: '18:00:00'
before: '09:00:00'
service: switch.turn_on
data: {}
Manually turn switch on/off works without problems. But after that automation is not fired at all.
Execute trigger manually also work. But even if trigger is false, is this ok? For example temp is over 22.0 and when i execute automation manually it turn on switch/pump.
I was watching this for days to thinking maybe i will see some logic but no success.
In log i can see that CCU values are updated ever minute:
2020-11-11 06:39:36 DEBUG (SyncWorker_30) [pyhomematic._hm] ServerThread.getAllSystemVariables: Getting all System variables via JSON-RPC
2020-11-11 06:39:36 DEBUG (SyncWorker_30) [pyhomematic._hm] RPCFunctions.jsonRpcPost: Method: Session.login
2020-11-11 06:39:36 DEBUG (SyncWorker_30) [pyhomematic._hm] RPCFunctions.jsonRpcPost: API-Endpoint: http://192.168.178.39:80/api/homematic.cgi
2020-11-11 06:39:36 DEBUG (SyncWorker_30) [pyhomematic._hm] RPCFunctions.jsonRpcPost: Method: SysVar.getAll
2020-11-11 06:39:36 DEBUG (SyncWorker_30) [pyhomematic._hm] RPCFunctions.jsonRpcPost: Method: Session.logout
Thanks for help.
