I’m having some troubles when I try to limit how often I can get a notification.
I’m trying to get notified if there’s trouble with processor, memory, disk or temperature. Here’s my automation:
alias: PI har det ikke godt
description: ''
- platform: numeric_state
entity_id: sensor.processor_use_percent
above: '80'
for: '01:00'
entity_id: sensor.memory_use_percent
above: '80'
for: '01:00'
entity_id: sensor.disk_use_percent
above: '80'
for: '01:00'
entity_id: sensor.processor_temperature
above: '80'
for: '01:00'
condition:
- condition: template
value_template: >-
{{ (as_timestamp(now()) -
as_timestamp(states.automation.pi_har_det_ikke_godt.attributes.last_triggered
| default(0)) | int > 300)}}
- service: notify.mobile_app_redmi_note_9s
title: Raspberry PI does not feel well!
message: |-
{% if trigger.entity_id == states('sensor.processor_use_percent') %}
CPU Usage is {{ trigger.to_state.state }} percent
{% elif trigger.entity_id == states('sensor.memory_use_percent') %}
Memory usage is {{ trigger.to_state.state }} percent
{% elif trigger.entity_id == states('sensor.disk_use_percent') %}
Disk usage is {{ trigger.to_state.state }} percent
{% elif trigger.entity_id == states('sensor.processor_temperature') %}
Processor temperature is {{ trigger.to_state.state }} degrees
{% else %}
Dont know which entity trigged this alarm.
{% endif %}
mode: single
If I try to execute the automation it keeps doing the action part and sending me notifications - I want it to be limited to 1 notification per 5 minutes as a start. Can anyone help me?
