I’m looking to include both the current and previous state value in a notification when a sensor value changes. I have mocked up a simple automation using speedtest. Then below does NOT give me the “from” value when I use states('trigger.from_state'), states('trigger.from_state.state').
Is the trigger value NOT available in the notification section, or do I have something incorrect here?
Thank you kindly,
CDL
service: persistent_notification.create
data_template:
title: Network Speed Alert
message: XFinity Download Speed Changed to {{states('sensor.speedtest_download')}}, from {{states('trigger.from_state')}}`
If the automation is using a State Trigger to monitor the state-changes of sensor.speedtest_download, then this is how to report the sensor’s current and previous values:
message: 'XFinity Download Speed Changed to {{trigger.to_state.state}}, from {{trigger.from_state.state}}'
For more information about the trigger variable when used with a State Trigger, refer to Templating - State.
Was totally how i was testing it, thank you! Is there any way to do a conditional in the messages so I can test in demand, e.g.: if(trigger is nothing) {sensor.state} else {trigger.state} type logic?
service: notify.persistent_notification
message: >
XFinity Download Speed Changed to {% if trigger is defined and
trigger.from_state is defined -%}
{{ trigger.to_state.state }}, from {{ trigger.from_state.state }}
{%- else -%}
{{ states('sensor.speedtest_download') }}
{% endif %}
NOTE
The use of the hyphen in -%} is for whitespace control (include/exclude spaces and newlines in the rendered text).
Be advised that you don’t normally test automations by manually triggering them. For more information, refer to Troubleshooting Automations.
