Automation Now Fails after Core Update
Hi all my automations now fail following an update to the latest core version (2025.3.4) with similar errors to :-
Anybody got any ideas what has happened or how I go about getting them to work again?
Steve
Hello
My first thought is to restart Home Assistant after a configuration check to make sure everything restarted completely and correctly after the update.
Open your Home Assistant instance and show your server controls.
If that doesn’t solve your issue will need to give us your YAML code formatted so we can see it to be of any help.
How to help us help you - or How to ask a good question.
A restart of home assistant did it. I had closed the application after the update several times but not done a restart, although I hadn’t needed to for previous updates.
Strange that only some of the automations failed but I’ll remember it for the future!
Many thanks for your help!
Steve
