JoernESP
(Joern)
February 27, 2021, 12:56pm
1
I would like to start a fan, if humidy in one room is higher than values of normal room humidy in other areas.
It works nice, when I only trigger by value comp. (see below), but checking comparison of sensors every minutes does not work.
Should compare every minute, but nothing happens …
- alias: 'Turn fan on'
- platform: time_pattern
minutes: "/1"
condition:
condition: and
conditions:
- condition: template
value_template: '{{ ( sensor.humidity_hwr3 ) > ( sensor.humindity1esp ) }}'
service: switch.turn_on
entity_id: switch.fan_dg
Following work fine:
platform: numeric_state
entity_id: sensor.humidity_hwr3
above: 50
JoernESP
(Joern)
February 27, 2021, 1:04pm
3
Update - seems I get also a error logs every minute:
Error during template condition: UndefinedError: ‘sensor’ is undefined
Your non working automation doesn’t do anything at all, you just added the sensor name in the template, but you need to get the state of the sensor, with states(...)
. Also conditions are and by default and you anyway have obly one condition, so your and condition is unnecessary.
minutes: "/1"
condition:
value_template: "{{ states('sensor.humidity_hwr3') | float > states('sensor.humindity1esp') | float }}"
Edit:
It would be better to trigger only whrn the condition is true and not every minute:
platform: template
Your value template is wrong . Also it would be best to compare trigger the automation only when the sensor value changes. please try this
alias: New Automation
description: ''
mode: single
- platform: state
entity_id: sensor.humindity1esp
- platform: state
condition:
JoernESP
(Joern)
February 27, 2021, 1:20pm
6
Hallo,
works very well! Thanks a lot!
