Hello everybody
I have try to divide automaion in several file with automation old configuration and merge_dir_merge_list but he seem no automation in these file are load in home assistant and i have no error in log maybe this option is depreciated now?
jocnnor
(Jim O'Connor)
February 7, 2020, 11:12pm
2
merge_dir_merge_list isn’t a valid one. You probably meant “include_dir_merge_list”
Automations are a list, so
automations: !include_dir_merge_list automation_folder_name/
jocnnor:
yes is that I have put
automation old: !include_dir_merge_list automations
but if I put
automation UI will not work anymore?
AhmadK
(akasma74)
February 8, 2020, 3:47pm
4
should be
automation: !include_dir_merge_list automations/
and you probably need to move your automations.yaml
into that folder, too.
Hi all I have found my mistake I put in yaml fil extention ".yml’ and the include must only import “.yaml” file.
now this cconfig work great
for information you need to keep automations.yaml in root configuration because ui write automation by default to this path
thanks for your help
AhmadK
(akasma74)
February 8, 2020, 6:46pm
6
but that’s exactly what you posted here saying it works… confusing!
p.s I know about automations.yaml
at root level, was unsure about your intentions though…
Yes it s work now because i have change automation file extemantion from .yml to .yaml
MrBorg
(P. Borg)
May 18, 2020, 9:51am
9
Oh I am still a little confused. How do a get new automation UI and old YAML automation folder work side-by-side. I tried setting up this:
But this morning my home was cold - no automations (old ones) had been activated. How can I keep my old automation YAML files being unchanged and then only use automation.yaml in root for new UI automations. What do the documentation actually say in this part - what and where should I put this line:
After automation old include configurations you need to have a folder name automations ans put .yaml with tour old automation inside
PS you don t need in this case to but automation old: in your automation file
MrBorg
(P. Borg)
May 18, 2020, 11:24am
11
Well that I already have - but I found a misspelling in the include reference “automations vs. automation”.
But is this enough ? Or should I also include this part anywhere and Where then?
you can find below my configuration for automation
in configuration.yaml add include
I have a folder name automations who contain all my automation
and this is an exmaple of automation file
as you can see you don’t need to put
- automation old:
at the begining of automation
petro
(Petro)
May 18, 2020, 4:34pm
13
Think you spelled bedroom wrong
