Automation on state change unless it was or becomes a certain state
I am trying to build an automation which triggers on the state change of our cat flap however it regularly becomes unavailable.
I would like to add a condition that checks the state change hasn’t gone to or from Unavailable but I am really struggling to think how to do it in HA.
I have very little knowledge how to use node red but would consider it if that is a recommended solution.
Is it a binary state - eg open/closed? If so two triggers - from closed to open and from open to closed should exclude any unavailable states. If you want to know when the flap is unavailable a third trigger for that. Then a choose action depending on which trigger fired.
For example:
description: ""
mode: single
  - platform: state
    entity_id:
      - binary_sensor.catflap
    to: "on"
  - platform: state
    entity_id:
    to: "off"
  - platform: state
    entity_id:
    to: unavailable
condition: []
  - choose:
      - conditions:
          - condition: trigger
            id:
              - open
        sequence: []
      - conditions:
            id:
              - closed
        sequence: []
      - conditions:
            id:
              - unavailable
        sequence: []
The poor cat must get shut out a lot! :unamused:
Something like this may help:
description: ""
mode: single
  - platform: state
    entity_id:
      - binary_sensor.lumi_lumi_sensor_magnet_aq2_opening_2
    not_from: unavailable
condition:
  - condition: not
    conditions:
      - condition: state
        entity_id: binary_sensor.lumi_lumi_sensor_magnet_aq2_opening_2
        state: unavailable
action: []
The not_from isn’t available to select from the UI but is available when the Yaml is edited directly.
Thankfully the RFID scanner still works so no issue to the cat, just means I can’t remotely control it.
