I have an automation for each door, window and motion sensor that I have which logs to a google sheet using ifttt. I’m using mutiple triggers in one automation and I want pull through the friendly_name field into the google sheet. I know I can use :
However without creating an automation for each sensor is there a way I can pull through which ever trigger was activated and stick it where the “SENSOR” is above?
