Hi guys. I have a dumb tv controlled by broadlink rm mini. Is there a way to make home assistant remember which HDMI input it is in? some kind of a tracker
If the boardlink doesn’t report a state, then your only option is to attempt to sync the two up. But that won’t work if you use the physical remote to change the input.
Hi. I am interested in knowing how to sync it.
how are you currently changing the input?
Im using the broadlink platform in HA with smart ir addon
are they separately called services for each input?
Hi. Its the same service. I call it multiple times to change source
So, lets say you have 5 inputs, each having a different service. You would then create an input_select that has 5 different names that match your inputs. You then create 5 different scripts. Each script calls 2 services. The first service being input_select.select_option, and you’d select the appropriate input. The second service would be sending the RF command to change the source/input.
Then when you want to know what input is being used, just look at the input_select.
The problem with this method is that if you change the input outside the home assistant app, you’ll be out of sync with the input_select.
If you post the services, I can help you tailor this whole setup.
Hi. thanks you for your help.
This is the relevant configuration.yaml
switch:
- platform: broadlink
host: 192.168.1.101
mac: '24:df:a7:de:f8:fc'
type: rm_mini3_redbean
media_player:
- platform: smartir
name: Living room TV
unique_id: living_room_tv
device_code: 1020
controller_data: 192.168.1.101
power_sensor: switch.sonoff_100090867f
This is the service called to change the input:-
source: Input
entity_id: media_player.living_room_tv
service: media_player.select_source
My inputs are
- TV
- HDMI 1
- HDMI 2
- HDMI 3
- PC
I looked at the input_select integration.
can it remember the value after a restart?
the documentation says i need a initial value. Does it mean i have to sync everytime I restart HA?
So the service call just Cycles the input?
yes. This is the script i currently use to change between 2 of the HDMI inputs.
'1592989684785':
alias: Kodi to Chromecast
sequence:
- data:
source: Input
- delay: 00:00:01
- data:
source: Input
- delay: 00:00:01
- data:
source: Input
- delay: 00:00:01
- data:
source: Input
- delay: 00:00:01
- data:
source: Input
'1592990100766':
alias: Chromecast to kodi
sequence:
- data:
source: Input
- delay: 00:00:01
- data:
source: Input
Hi @petro,
With your guidance, i managed to solve it with a few scripts and automation. Input select was the key.
