Automation script not firing, more logs?
Hi, so i have an automation script that turns on our outside lights at sunset. It’s been working well, i also have a timer to turn them off at 00:00 too.
However, on 2 occasions they have not fired, and there is nothing related in home-assistant.log, so where can i find more detailed logs on what’s failing?
You could try setting the logger to a lower level of information like info or debug temporarily, then try triggering the automation manually a few times.
I also already wondered how to change the log level, is there an entry in the doc about that?
EDIT: Just found it: https://home-assistant.io/components/logger/
(Never really searched before ^^)
I use a shortcut to site search the HA site:
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=site%3A%20https%3A%2F%2Fhomeassistant.io
Click on this and then save it in your bookmarks; it comes in real handy.
