Can someone put me out of my misery? What am I doing wrong…
automation:
- id: emptyhouse
alias: No-one Home
- platform: state
entity_id: climate.wts
to: 'heat'
condition:
condition: or
conditions:
- condition: and
conditions:
# reports 'home' if anyone is home - so check no-one is home
- condition: state
entity_id: group.mypeople
state: 'not_home'
for: '01:00:00'
# and its not a day when pete comes to work
- condition: state
entity_id: binary_sensor.pete_expected
state: 'off'
# or if the temp outside is hot
- condition: template
value_template: "{% if states('sensor.dark_sky_daytime_high_temperature_0d')|int > 24 %} true {% else %} false {% endif %}"
# force heating off regardless
- condition: state
entity_id: binary_sensor.heating_off
state: 'on'
- service: climate.set_temperature
temperature: >
{{states('input_number.fix_temp') | float}}
This is ‘valid’ config but errors when triggered from services with skip_conditions: true
Error executing script. Invalid data for call_service at pos 1: expected float for dictionary value @ data['temperature']
It does the same if I do this
temperature: "{{states('input_number.fix_temp') | float}}"
or remove the cast to float.
It works fine if I put an actual number there instead.
