Hello there!
I am trying to automate a daylight alarm clock. It should read the next alarm comig up at my phone and then if its a maximum of 10 minutes to go the lights should start.
There are 2 lights in the lamp - one in the bottom and one in the top. So I am starting the bottom light first and the top one second.
My logs give me this:
Invalid config for [automation]: invalid template (TemplateSyntaxError: tag name expected) for dictionary value @ data['action'][0]['repeat']['sequence'][0]['repeat']['sequence'][0]['data']. Got None. (See /config/configuration.yaml, line 18)
And here is my automation:
- id: 'xxxxxx'
alias: Alarm_clock
value_template: "{% ( as_timestamp(now())+600 | int ) > ((state_attr('sensor.oneplus_a5000_next_alarm', 'Time in Milliseconds') /1000) | int) > ( as_timestamp(now()) | int ) %}"
condition:
- condition: zone
entity_id: person.me
zone: zone.home
- repeat:
until:
- condition: numeric_state
entity_id: light.novo7w_2
value_template: states.light.novo7w_2.attributes.brightness
above: 254
sequence:
- repeat:
until:
entity_id: light.novo7w_1
value_template: states.light.novo7w_1.attributes.brightness
above: 150
sequence:
- service: light.turn_on
brightness: '{% (50 + repeat.index) %}'
rgb_color: [255,'{% repeat.index %}','{% (((-170 + repeat.index), 0) | max) %}']
- delay: 3
- repeat:
until:
above: 254
sequence:
brightness: '{% ((200 + repeat.index), 255) | min %}'
rgb_color: [255,'{% 50 + repeat.index %}','{% ((-150 + repeat.index), 0) | max %}']
color_temp: '{% (500 - repeat.index) %}'
white_value: '{% (50 + repeat.index) %}'
- delay: 2
mode: single
Would love to find my problem. Thank you in advance!
