I have the Aeotec Multisensor 7. I’m trying to create an automation that sends a notification when a device has stopped vibrating after vibrating for more than 5 minutes. The sensor does not expose an entity for vibration but rather uses a notification. This means I can’t create an automation based on “vibration stopped” but only when it starts. I have this existing automation:
alias: Multisensor 7 Tamper Detection
description: ""
triggers:
- device_id: abc123
domain: zwave_js
type: event.notification.notification
command_class: 113
type.: "7"
label: Home Security
event: "9"
trigger: device
conditions: []
actions: []
mode: single
and it triggers as expected, at most every 60 seconds, when vibration is detected. So far so good
My end goal is to
- Send a notification
- When the device stops vibrating
- But only if it was vibrating for more than 5 minutes
Sometimes the device is bumped, so I don’t want to send a notification every time vibration stops.
How should I build this?
