long story shot … im sending an alarm from my iOSdevice- the alarm is ok recieved and handled by HA. the time set in the alarm should be used in an automatin that fires a sunrice script… problem. The automation dosent trigger the script . The script runs fine when i manuel pres “run”
made an test automation to just to cut al the other things away…
alias: TEST 13:22 - Automation → Script
description: ""
triggers:
- at: "13:22:00"
trigger: time
actions:
- target:
entity_id: script.solopgangslys_sovevaerelse_9m50s
action: script.turn_on
mode: single
And the original automation
alias: Solopgang - 10 min før iOS alarm
description: Starter solopgangslys 10 min før næste iOS-alarm
triggers:
- entity_id: sensor.korrigeret_ios_alarm
trigger: state
conditions:
- condition: template
value_template: |
{{ states('sensor.korrigeret_ios_alarm') not in
['unknown', 'unavailable', '', none] }}
actions:
- variables:
alarm_ts: "{{ as_timestamp(states('sensor.korrigeret_ios_alarm')) }}"
now_ts: "{{ as_timestamp(now()) }}"
delay_seconds: "{{ (alarm_ts - now_ts - 600) | int(0) }}"
value_template: "{{ delay_seconds > 0 }}"
- delay:
seconds: "{{ delay_seconds }}"
- target:
mode: single
max_exceeded: silent
I cant even tell where i have been so frawith this automations , but many test … im giving up and call in the cavalery ![]()
The script
alias: Solopgangslys - soveværelse (9m50s)
sequence:
- variables:
duration: 590
step_seconds: 10
steps: 59
start_brightness: 8
end_brightness: 210
start_kelvin: 2000
end_kelvin: 4000
- repeat:
count: "{{ steps | int }}"
sequence:
- variables:
fraction: "{{ (repeat.index - 1) / (steps - 1) if steps > 1 else 1 }}"
brightness: >-
{{ (start_brightness + fraction * (end_brightness -
start_brightness)) | int }}
kelvin: >-
{{ (start_kelvin + fraction * (end_kelvin - start_kelvin)) | int
color_temp_mireds: "{{ (1000000 / kelvin) | int }}"
- target:
entity_id:
- light.lightstrip_under_seng_lys
- light.loft
- light.skab_1
- light.skab_2
- light.skab_3
- light.skab_4
brightness: "{{ brightness }}"
color_temp: "{{ color_temp_mireds }}"
transition: "{{ step_seconds }}"
action: light.turn_on
- delay:
seconds: "{{ step_seconds }}"
- target:
entity_id:
- light.loft
- light.skab_1
- light.skab_2
- light.skab_3
- light.skab_4
brightness: "{{ end_brightness }}"
color_temp: "{{ (1000000 / end_kelvin) | int }}"
transition: 5
mode: single
icon: mdi:weather-sunset-up
description: ""
Ps im sorry for the wron word “trigger” when speaking af script . how about “run”
