Automation to change assist
Is there a way via automation to change speech-to-text or text-to-speech or conversational agent of an assist? This way I could use local voice recognition and llm while my computer is on and use cloud systems while it is off
Create two pipeline and switch between them.
alias: voice-agent_change
description: ""
triggers:
  - trigger: conversation
    command:
      - Смени[ть] режим
conditions: []
actions:
  - if:
      - condition: state
        entity_id: select.wsat_assist_pipeline
        state: Home Assistant
    then:
      - action: select.select_option
        metadata: {}
          option: AI
      - set_conversation_response: Агент изменён на сбер
    else:
        metadata: {}
          option: Home Assistant
      - set_conversation_response: Основной агент выбран
mode: single
sorry how to create two pipelines? You mean more than one assist? I don’t have any entity starting with “select.”
Aѕsiѕt is a voice module in HA in a general sense. Inside it you configure pipelines(settings - voice assistant).
The selector is the entity of your satellite
I see, thanks
