The behavior I’m trying to accomplish by tapping an NFC tag with my phone
First tap. Scene 1 (Turn on light bright)
Next tap. Scene 2 (Set brightness 25%)
Next tap. Turn off light
Is this Doable?
Ok… I’ve figured this out.
Hopefully this helps someone else.
I’ve created 4 scenes
Bright
Dim
TV
Off
Then I created a text input helper
I set the value to Off (my lights were off)
I added an NFC Tag
In my automation
Using choice
I activate the scene based on the input text value and then set input text value to the current scene.
alias: Living Room Tag lights
description: ""
- platform: tag
tag_id: 9dd1e13e-3fdc-427c-b046-f32f581b45ef
- platform: tag
tag_id: 9a9f6b58-e4db-4f6d-afd8-d2cac9476adb
condition: []
- choose:
- conditions:
- condition: state
entity_id: input_text.living_room_active_scene
state: "Off"
sequence:
- service: scene.turn_on
entity_id: scene.lrlights_warm_white
metadata: {}
- service: input_text.set_value
value: Warm
- conditions:
- condition: state
state: Warm
sequence:
entity_id: scene.living_room_dim
metadata: {}
value: Dim
- conditions:
- condition: state
state: Dim
sequence:
entity_id: scene.living_room_tv
metadata: {}
value: TV
- conditions:
- condition: state
state: TV
sequence:
entity_id: scene.living_room_off
metadata: {}
value: "Off"
mode: single
Create an Input Select with the following four options (in this exact order):
Create the following automation:
description: ""
- platform: tag
- platform: tag
condition: []
- variables:
selection: input_select.living_room_active_scene
scenes:
Off: lrlights_warm_white
Warm: living_room_dim
Dim: living_room_tv
TV: living_room_off
entity_id: "scene.{{ scenes.get(states(selection), 'living_room_off') }}"
- service: input_select.select_next
entity_id: '{{ selection}}'
mode: single
