I have a user code for guests/babysitters/petsitters for my Schlage lock. I’d like to rotate it on a weekly basis to a new random code, and would love for it to be automated/have it send out the code on TG. I see the “lock.set_usercode” service and figure I’d do it that way, but I can’t figure out the automated bit/how to get it sent out via TG. Anybody do this/have ideas?
I don’t have such a lock so have no idea how that service works, but for the random code i’d use this component:
this will give you a random number. If you need more than one, for like a 4 digit code, use 4 sensors, one per digit.
Hope that helps.
I guess you’ll have to use something like:
- service: lock.set_usercode
node_id: 44
code_slot: 4
data_template:
usercode: "{{states.sensor.pin_code.state}}"
Figured it out. Combination of random sensor and input_number run in a script. Thanks all! If anybody wants the code, just let me know.
I’d be interested in taking a look at the code.
Note: this is for a 6 digit combination. If you have 4 or 8, you’d need to tweak the number of random sensors and the input_number.
First, add random sensors:
##### Random for Locks
- platform: random
minimum: 10
maximum: 99
- platform: random
minimum: 10
maximum: 99
- platform: random
minimum: 10
maximum: 99
Next, add an input_number to your configuration.yaml.
input_number:
guest_code:
initial: 123456
min: 100000
max: 999999
step: 1
Once you do that, add a script to run the change (insert your values for XXXX):
# Set Guest Code with random numbers
guest_lock_code:
alias: Generate and Set Guest Code
sequence:
- service: input_number.set_value
data_template:
entity_id: input_number.guest_code
value: "{{ states.sensor.first_set.state | int }}{{ states.sensor.second_set.state | int }}{{ states.sensor.third_set.state | int }}"
data_template: {
"node_id": XXXX,
"code_slot": XXXX,
"usercode": "{{ states.input_number.guest_code.state | int }}"
- service: notify.XXXX
data_template:
message: "*New Guest User Code Generated* \n The new code for the week is: {{ states.input_number.guest_code.state | int }}"
Finally, add an automation to run the script however often you want. My is once a week on Sunday.
- alias: "Security - Weekly Door Code Rotate"
hide_entity: True
platform: time
at: '09:00:00'
condition:
condition: time
weekday:
- sun
- service: script.guest_lock_code
