brendan
(Brendan)
August 1, 2020, 4:15am
1
I am not sure if I am in the correct place, but I would like to create an automation that will trigger when a particular user logs in to Home Assistant.
As an example:
trigger: User Joe Blogg logs in to Home Assistant interface.
action: A notification is sent to push_bullet.
Is this possible? I have had a look around and not quite found how to do it.
brendan
(Brendan)
August 1, 2020, 4:54am
3
Thanks @nickrout . I was hoping there might be an official way, but a custom is going to be a good solution too
I hope they have official logging included as the authentication improves.
Thanks again
nickrout
(Nick Rout)
August 1, 2020, 4:55am
4
There may be an event associated with a login, but I couldn’t find it!
brendan
(Brendan)
August 1, 2020, 5:03am
5
That was the issue I had as well.
Thanks for finding the custom component
If anyone does know of an event for login, I’d still be interested in that.
theCheek
(The Cheek)
February 26, 2021, 9:27am
6
did you ever find a solution to this? I’m also looking to trigger stuff when a specific user logs in.
jatgm1
(jatgm1)
February 26, 2021, 9:46pm
7
Ya how do you specify just like one particular user?
nickrout
(Nick Rout)
February 26, 2021, 10:20pm
8
I suspect what you need to look to trigger on the attribute last_authenticated_time
with a condition of the attribute username
jatgm1
(jatgm1)
February 27, 2021, 12:35am
9
Is there something I can add that allows it to send the date and time of the last authenticated state, or whatever other data? Can I just put like %time% or %country% %reigon% %city% to have it send the data of the country region and City it has in states?
theCheek
(The Cheek)
February 27, 2021, 8:20am
11
thanks, but to what entity are you referring? Can’t find any attributes called last_authenticaed_time in HA.
nickrout
(Nick Rout)
February 27, 2021, 7:00pm
12
sensor.last_successful_authentication
Has attributes incl username
and last_authenticated_time
jatgm1
(jatgm1)
February 28, 2021, 2:38am
13
Can verify this. Make sure to add to config
Sensor:
Some other stuff I can’t remember
Idk it’s on the authenticated page.
Also Install authenticated from hacs
Broken in HA 2022.4 - all attributes missing. Therefore unfortunately pretty useless
Looking for
a) reason
b) alternatives
Hints warmly welcome.
Is this now totally not working for everyone or still working for some?
thanks
jatgm1
(jatgm1)
June 15, 2022, 10:45pm
16
Ya seriously this was useful why doesn’t it work now that sucks
