Automation to turn lights on 15 minutes after sunset turns them on at wrong sunset time
I have an automation that I’m using to control 3 smartplugs. I set it up yesterday but this morning it triggered at 10:45 AM local time. The logs show a sunset event at 10:30 AM local time. They are turning off correctly at 9:30 PM local time. I am not showing any sunrise or sunset events for my actual location.
I suspect this is related to an earlier problem I had - Home Assistant insisted on showing my zone as being in Amsterdam. Indeed, just now I checked the Areas & Zones page and when I went to Zones, it showed Amsterdam. In fact, if I go to Settings | System | General and click on Edit Location after a restart - the first time it shows me as being in Amsterdam. Subsequent visits show the location I set as my home.
When I look at the sunrise and sunsets time for Amsterdam, it seems about right for the times I’m seeing in my logs when converted to my local time.
However, clearly the default Amsterdam location is still recorded in some configuration somewhere and is being used to trigger sunrise and sunset events. How can I get rid of it?
