Automation to turn on and off device based on fixed time
i’m planning to create automation to turn on and off plug based on fixed time. I want to turn plug on 06:00 am and turn it off at 08:00 am so it will run 2 hours (so basically off → on → off). Can or should I do this using one automation or two (one to turn plug on and another turn it off).
Two automations is better.
If you use one and a delay in between then a restart will make the off not work.
I would even say that instead of fixed times make sure the time is “if time is past 08:00” then turn off.
Since a fixed time automation also could fail if the restart is 07:59:59
With two automations that doesn’t necessarily mean two automations.
You could have one automation with two triggers and trigger IDs that you use in the action.
The best practice is to use 2 automations which trigger at your on and off times. This will mean that if there is an inadvertent restart of HA during your 2 hours it will still turn off automatically.
This is what I would do. Keeps it nice and tidy. I’d also use input_datetime entities for the triggers so the times can be altered from Lovelace nice and easily.
Any help for a newbie? I don’t understand code, and when I’ve tried researching how to do this I keep getting code blocks and people talking in the thread who seem to understand what they’re talking about - but I don’t
Is there a newbies guide to scheduling simple On & Off schedules for a garden light? I am thoroughly confused. On my home assistant dashboard I have a card with the on/off toggle as an “Entity” but have no idea what to do now
Thank you!
Start here:
