Automation - trigger doesn't appear when IKEA cover is opening
Having observed the last period, I’ve found a pattern I would like to use in an automation.
So when the bedroom cover opens, and the light in the kitchen is on, and it is morning,it should turn on the coffee machine.
So I did this:
- id: '1582005662999'
  alias: Kitchen - turn on coffeemachine when curtain goes up
  description: ''
  - device_id: 2bf1e4e20e774e14b96e3d66b87c0a27
    domain: cover
    entity_id: cover.rullegardin_i_sovevaerelse
    platform: device
    type: opening
  condition:
  - after: 05:00
    before: '12:00'
    condition: time
  - condition: state
    entity_id: group.lys_koekken
    state: 'on'
  - entity_id: switch.coffeemachine_relay
    service: switch.turn_on
But I don’t see the switch getting turned on.
The curtain was opened via the IKEA remote.
The group was set to ‘on’ and the timeframe was correct, but no automation.
Will the automation be marked as triggered even if the conditions are false, or is it only when the conditions are met it’s marked? (just to narrow down there the problem is).
I’ll test more when I get home from work.
First thing I notice is you use quotes on the before time condition but not on the after.
Hmm, yes, it’s simply entered via the GUI…
That doesn’t make it right :wink:
No, I agree, I was just baffled for a second. I’ll correct it and test this afternoon again (changing the time frame).
I created the issue on github
Why did you create an issue? You should look at the developer - states page to see the actual state while opening.
There are triggers defined, so that it can react directly on the device, and not just the state, that’s some of the ‘newish’ features, and it doesn’t react, so yes, it’s an issue.
