phiwa
(Philipp)
December 17, 2017, 1:39pm
1
I am trying to use a input_number as a trigger but i can not use the input_number.
Is the syntax wrong or should i use the template trigger below?
autmations:
alias: co_wert_ueberschritten
platform: numeric_state
entity_id: sensor.co_gehalt_am_arduino
above: 140
#above: {{states.input_number.schwellwert_co.state | int }}
service: notify.Pushbullet
title: “CO Wert zu hoch”
message: “C0 Wert ist zu hoch: ‘{{states.sensor.co_gehalt_am_arduino.state }}’ ppm”
this way works not too:
- alias: co_wert_ueberschritten
-platform: template
value_template: "{{ states('input_number.schwellwert_co')| int > states('sensor.co_gehalt_am_arduino') |int }}"
- service: notify.Pushbullet
title: "CO Wert zu hoch"
message: "C0 Wert ist zu hoch: '{{states.sensor.co_gehalt_am_arduino.state }}' ppm"
keithh666
(Keith Hull)
December 17, 2017, 11:57pm
2
What I would do is trigger on just a state change of the sensor and then have a condition that checks the sensor value against the input_number, since above: can’t have a template in it. Your second automation I think would work if you changed it so that the sensor is checked against the input_number, in other words reverse it like so …{{ states(‘sensor.co_gehalt_am_arduino’)| int > states(‘input_number.schwellwert_co’) |int }}
kslb
(KSLBe)
November 4, 2019, 7:16pm
4
I have similar problem, but for me nothing is working correctly if I’m using input_number:
So my code for variable:
input_number:
variable_kabinet_prizgi_klima:
min: 16
max: 32
step: 0.5
unit_of_measurement: "°C"
and my code for automation:
# Prižgi KLIMA - KABINET: Če je temperaturni senzor več kot 23 stopinj
- id: '1502'
alias: KABINET - prižgi KLIMA
# platform: numeric_state
# entity_id: sensor.kabinet_t
# above: '23'
platform: template
value_template: “{{ states('sensor.kabinet_t')|int > states('input_number.variable_kabinet_prizgi_klima')|int }}”
for:
hours: 0
minutes: 15
seconds: 0
condition:
- condition: numeric_state
entity_id: sensor.zunaj_t
above: '4'
- service: climate.set_temperature
entity_id: climate.melcloud_XXX_9999999
temperature: '19'
- service: climate.set_fan_mode
fan_mode: 'Speed Auto'
- service: climate.set_hvac_mode
hvac_mode: 'cool'
- service: climate.set_swing_mode
swing_mode: 'Swing'
- service: notify.simon
message: "KABINET - vklop klime (hlajenje)."
title: "KLIMA VKLOP"
Do anybody know what I’m doing wrong?
If I’m using above function which is #, then all is working normally…
popboxgun
(ha_popbox)
November 5, 2019, 12:05am
6
The quotes look wrong in your value template.
123
(Taras)
November 5, 2019, 12:38am
7
If you run Config Check, does it report any errors for your automation?
kslb
(KSLBe)
November 5, 2019, 6:18am
8
No… everything is fine in Config Check. Quotes are not the problem… I’m using similar with input_datetime and it’s working fine:
Code:
platform: template
value_template: "{{ states('sensor.time') == (states.input_datetime.variable_zunaj_prizgi_led_zjutraj.attributes.timestamp | int | timestamp_custom('%H:%M', False)) }}"
So what is the wrong with syntax…?
kslb
(KSLBe)
November 5, 2019, 6:32am
9
I will try to change from:
to:
value_template: "{{ states('sensor.kabinet_t')|int < states('input_number.variable_kabinet_ugasni_klima')|int }}"
And we will see if this will fix the problem…
kslb
(KSLBe)
November 5, 2019, 11:24am
10
Nop, nothing helps… If I triger manual it’s working or if it’s static below value, but with value_template it’s not working…
So what should be wrong with there lines?
platform: template
value_template: "{{ states('sensor.kabinet_t') | int < states('input_number.variable_kabinet_ugasni_klima') | int }}"
hmm… anybody knows?
Or how to use in other way to replace static value:
below: '20'
Is the problem in “for” statement? If yes, how to use that in value_template…
123
(Taras)
November 5, 2019, 1:19pm
11
It works because when you trigger an automation manually, it skips trigger
and condition
and just executes the action
kslb
(KSLBe)
November 5, 2019, 1:22pm
12
Yes, the problem is somewhere in “for” condition under trigger… So I need to make teplate_value to be conditioned with time value…
popboxgun
(ha_popbox)
November 5, 2019, 7:15pm
13
I tested your code using a door sensor and everything worked.
- alias: A Test Automation
initial_state: on
platform: template
value_template: "{{ states('binary_sensor.visonic_mct_340_e_0b3e4322_1_1280') == 'off' }}"
for:
hours: 0
minutes: 5
seconds: 0
condition:
entity_id: sensor.office_lux_sensor
above: '4'
- service: script.slack_ha_channel
data_template:
message: >
The Office LUX is {{ states.sensor.office_lux_sensor.state }}
Are you sure your value_template is staying true for 15 minutes? Have you run it through the template in Developer Tools? Perhaps reduce the for from minutes to seconds to test.
kslb
(KSLBe)
November 6, 2019, 6:54am
14
The problem was, that I tried to use directly, so not via binary_sensor.
Sensor via input_number…
# SCHRACK - prižgi VENTILATOR (več kot 25)
variable_kabinet_prizgi_schrack_ventilator:
min: 15
max: 30
step: 0.1
I solve problem via binary_sensor.
# SCHRACK ventilator - prižgi/ugasni
sensors:
schrack_prizgi_ventilator_boolean:
friendly_name: "SCHRACK - prižgi ventilator (stanje)"
icon_template: mdi:gate-and
value_template: "{{ states('sensor.schrack_t') | int > states('input_number.variable_kabinet_prizgi_schrack_ventilator') | int }}"
And then via binary sensor I trigger automation…
# Prižgi SCHRACK ventilacijo - KABINET: Če je temperaturni senzor več kot 25 stopinj
- id: '3001'
alias: SCHRACK - prižgi VENTILATOR
# entity_id: sensor.schrack_t
# above: '25'
platform: template
value_template: "{{ is_state('binary_sensor.schrack_prizgi_ventilator_boolean', 'on') }}"
for:
hours: 0
minutes: 15
seconds: 0
condition:
- condition: state
entity_id: switch.schrack_fan
state: 'off'
- condition: state
entity_id: binary_sensor.schrack_ugasni_ventilator_boolean
state: 'off'
service: switch.turn_on
entity_id: switch.schrack_fan # Use the actual name of your switch here
And now it’s working…
123
(Taras)
November 6, 2019, 1:33pm
15
Now that you are simply monitoring the state of a binary_sensor, you can use a State Trigger:
platform: state
entity_id: binary_sensor.schrack_prizgi_ventilator_boolean
to: 'on'
for: '00:15:00'
EDIT
For future reference, in recent versions of Home Assistant, for
accepts a template (should you need it).
