Automation Trigger Question Specifying Units
Trying to setup a automation that HA notifies myself after the washer is done running. I have seen configuration written in the yaml file, but trying to set it up thru the GUI. How do I define the trigger when below 2 watts? I don’t know if I am supposed to use a symbol before it, and what to specify watts. Any suggestions?
You want a numeric state trigger, not a state trigger. This will give you an option for “below”.
No need to specify units.
Sweet, thanks for the quick response. I will give it a try. Thanks again.
