Hi all
I have an automation script that turns all lights on and flashes them different colours, and turns camera sirens on, if a door switch is detected as open on any door, between the hours of 1am - 7am:
alias: Intruder Alert
description: ""
triggers:
- type: opened
device_id: 7d33588875ea784e30e780b0a32e0848
entity_id: 0d9968874976bd9da433df5d08f8c3a9
domain: binary_sensor
trigger: device
- type: opened
device_id: 576e90acc854873b70fd08e609454c0f
entity_id: 7e979e3ead5f12cd70ab4af28c5d9767
trigger: device
- type: opened
device_id: 6d641d563841bf025f29d4fd1241c4de
entity_id: 052f02268f9ecd1164d91a8d40726af9
trigger: device
conditions:
- condition: time
after: "01:00:00"
before: "07:00:00"
enabled: true
- condition: not
conditions:
- condition: zone
entity_id: device_tracker.sm_s901b
zone: zone.home
enabled: false
actions:
- type: turn_on
device_id: 6d0ff2236ef7c0d135ffddd9b7bc66d4
entity_id: afe9eaa4cfd78a7dcc897e1fbfb2bc27
domain: switch
- type: turn_on
device_id: 480f9ecef6718f12c3a0996f6a1f625a
entity_id: ac9a490728c76b9ce9eb3d4cdf03c766
domain: switch
- type: turn_on
device_id: ba097e555282058a5b6a274b9af43a77
entity_id: 49cded21d8a691794ad493b25340371c
domain: switch
- action: light.turn_on
metadata: {}
data: {}
device_id:
- 5d18cc6411c3011811c57905b7df28a1
- 1dd16dfb2f6aca4b6ca80ecede155c0f
- 732ce499ec2604a4c1486274abcfa6c4
- d0c01f80f8fcd622071bb4181408bec1
- 948a8698ae619f8ce6f8fbc9870527d6
- abfb96da3df6b62c78114bc3ac9e154e
- repeat:
sequence:
metadata: {}
rgb_color:
- 255
- 0
- 0
flash: long
brightness_pct: 100
device_id:
- delay:
hours: 0
minutes: 0
seconds: 5
milliseconds: 0
metadata: {}
rgb_color:
- 0
- 0
- 255
brightness_pct: 100
flash: long
device_id:
- delay:
hours: 0
minutes: 0
seconds: 5
milliseconds: 0
while:
- condition: state
entity_id: input_boolean.all_sirens_off
state: "off"
mode: single
This keeps getting triggered even though no doors have been opened. When I check the trace it shows this:
I see that the first item has this info populated under the Changed Variables. What does this variable change mean exactly? Which variable was changed and how?
I assumed automation cannot trigger if the When conditions are not met so how is this happening? Any help greatly appreciated.
Cheers
