Looking for someone who knows (no ‘I thinks’ please)… I did not find this answer after doing a few searches and reading the Wiki.
I’m not asking for help writing an automation. I want to know/understand how HA evaluates the WHEN statements.
Looking for someone who understands at the source-code level how HA evaluates the WHEN trigger section.
Question:
How does HA evaluate the WHEN conditions of an Automation if there are multiple conditions that can be True at the same time?
The YAML below shows a simple (real world) example.
I want the Automation to trigger when the Helper changes to either Stay or Sleep but NOT if the Helper changes from “Stay → Sleep” or “Sleep → Stay”>
– in those two cases, I do not want automation actions at all.
I have set it to watch for all 4 cases, and exclude the latter 2 cases based on ID, but not sure that will work as HA would need to simultaneously record and use two IDs to evaluate the Automation.
Or, does the order they are listed in matter… and in my example, since conditions I want to avoid are listed first, they will be evaluated then no-op (automation will exit without action) – but when the triggers are ‘Stay’ or ‘Sleep’ actions will properly execute?
Thank you for the help HA experts!
alias: "House Modes 1 : Selector Armed with Bypass -> Arm Panel"
description: House Mode Selector triggers Alarmo Master to be set + Bypass
triggers:
- entity_id:
- input_select.house_mode_selector
trigger: state
to: Sleep
id: Stay to Sleep
- entity_id:
trigger: state
to: Stay
id: Sleep to Stay
- entity_id:
trigger: state
to: Sleep
- entity_id:
trigger: state
to: Stay
conditions:
- condition: state
entity_id: input_boolean.bypass_alarm_zones
state: "on"
actions:
- choose:
- conditions:
- condition: not
conditions:
- condition: trigger
id:
- Stay to Sleep
- Sleep to Stay
sequence:
- action: envisalink_new.alarm_keypress
metadata: {}
keypress: NNNNN
entity_id: alarm_control_panel.alarm_partition_1
- delay:
hours: 0
minutes: 0
seconds: 5
milliseconds: 0
- action: alarm_control_panel.alarm_arm_night
metadata: {}
data: {}
mode: single
