I have these 2 input_numbers
I am trying to make sure the MIN can not be set above the MAX.
With the automation below, it works … the MIN value is set to 20
alias: Range Limit Automation - min
description: ""
triggers:
- trigger: numeric_state
entity_id: input_number.lht52_a840414e4f5cae3d_alarm_temp_min
above: input_number.lht52_a840414e4f5cae3d_alarm_temp_max
actions:
- action: input_number.set_value
value: 20
mode: restart
So far - so good.
But I want to set MIN to the current value of MAX
I tried the automation below
description: ""
triggers:
actions:
data_template:
value: "{{ input_number.lht52_a840414e4f5cae3d_alarm_temp_max.state | float }}"
mode: restart
But get this error: ... Error rendering data template: UndefinedError: 'input_number' is undefined
What am I doing wrong?
fuatakgun
(Fuat Akgün)
May 22, 2025, 5:07am
3
For data template, use this
{{ states(“input_number.name_goes_here”) }}
Bingo! That is the fix I needed.
Now - I just need to have it work ‘continuously’
When I first move the MIN slider above the MAX, it gets limited.
But not the next time
Troon
(Troon)
May 22, 2025, 6:47am
5
Trigger off any change to the sliders, and add a condition block to check if MIN is above MAX.
The set_value
action should use value
instead of the legacy data_template
(docs ).
Still having problems
alias: New automation
description: ""
triggers:
entity_id:
- input_number.lht52_alarm_temp_min
above: input_number.lht52_alarm_temp_max
conditions: []
actions:
- action: number.set_value
metadata: {}
value: "{{ states('input_number.lht52_alarm_temp_max') | int - 1}}"
entity_id: input_number.lht52_alarm_temp_min
mode: restart
To me this says
If
MIN > MAX
then
MIN = (MAX -1 )
But it is not working that way. I can see the automation is being triggered, and no errors reported. But the MIN value ends up saying above MAX.
Troon
(Troon)
May 22, 2025, 9:48am
7
You’ve changed it from input_number.set_value
to number.set_value
. Why did you do that? That action won’t update an Input Number, which is a different type of entity to a Number.
See my post above for advice on getting around the issue that a numeric state trigger only fires when the threshold is crossed, and it also doesn’t fire if the comparator entity changes .
Untested and typed on a phone:
description: ""
triggers:
- trigger: state
entity_id:
- input_number.lht52_alarm_temp_max
conditions:
- condition: numeric_state
actions:
value: "{{ states('input_number.lht52_alarm_temp_max') | int - 1 }}"
Thanks that helped … but it still only ‘works once’. I can see the automation triggering every time I move the MAX slider … but it only performs that action once per crossing the MIN threshold.
TEST 1 = Good
Min=10
Max=20
Move Max to 0
=> Max gets set to 11
TEST 2 = BAD
Continue from Test 1
Min=10
Max=11
Move Max to 0
Automation triggers
But - Max stays at 0
My understanding of the automation below is:
every time MAX changes AND MAX < MIN
then MAX = MIN + 1
alias: Limit Temp Max
description: Limit Temp Max
triggers:
- trigger: state
entity_id:
conditions:
entity_id: input_number.lht52_alarm_temp_max
below: input_number.lht52_alarm_temp_min
actions:
metadata: {}
value: "{{ states('input_number.lht52_alarm_temp_min') | int + 1}}"
mode: restart
Troon
(Troon)
May 23, 2025, 6:28am
9
Download the trace file for test 2 and paste it here.
What are the configured minimum and maximum values for your input numbers?
Also try with mode: single
I gave up.
Moved to Plan B
. Simple. Works
