I have different areas of the house with different brightness throughout the day
All on the same segments but different levels.
I can also (at any switch) force full brightness
So for the bathroom group
Any light comes on it comes on at service template brightness: “{{ states(‘input_number.in_light_bathroom_level’) }}”
And I have the segments trigger the different values at different times of the day.
If a light is on at a segment change then it too is changed but on a 180 second transition
For what ?
Switching the light on ?
The segments of the day ?
The storage values ?
Transitions on segment changes ?
Here is the light on automation and the segment changes driven by sensor boolean’s
automation:
#name: Light Bath Off Delay
- alias: au_light_bath_offdelay
- platform: state
entity_id: light.fibdim2_bath_level
to: 'on'
condition:
- condition: state
entity_id: input_boolean.ib_light_bath_timer_enable
state: 'on'
- service: light.turn_on
data_template:
brightness_pct: >
{{ states('input_number.in_aalight_bth_lvl') | int }}
transition: >
{{ states('input_number.in_aalight_segment_transition') | int }}
- service: script.turn_off
entity_id: script.sc_light_bath_timer
- service: script.sc_light_bath_timer
script:
sc_light_bath_timer:
alias: Light Bath Timer Script
sequence:
- delay: "00:{{ states('input_number.in_light_bath_timer') | int }}:00"
- service: light.turn_off
- alias: au_light_adjust_brightness_bthr
- platform: state
entity_id: input_number.in_aalight_bth_lvl
condition:
- condition: state
state: 'on'
data_template:
brightness_pct: "{{ states('input_number.in_aalight_bth_lvl') | int }}"
transition: "{{ states('input_number.in_aalight_segment_transition') | int }}"
binary_sensor:
sensors:
## day segment bs
bs_light_day:
entity_id: sensor.time
value_template: >
{% set rising = state_attr('sun.sun', 'rising') %}
{% set elevation = state_attr('sun.sun', 'elevation') | float %}
{% set daystart = states('input_number.in_aalight_day') | float %}
{% set eveningstart = states('input_number.in_aalight_evening') | float %}
{% set day = (rising and elevation > daystart) or (not rising and elevation > eveningstart) %}
{{ day }}
friendly_name: Day Lights
icon_template: "{{ 'mdi:white-balance-sunny' }}"
## evening segment bs
bs_light_evening:
value_template: >
{% set time = states('sensor.time') %}
{% set nightstart = states('input_datetime.id_aalight_night') [0:5] %}
{% set nightstart = '23:59' if nightstart == '00:00' else nightstart %}
{% if '12:00' < nightstart <= '24:00' %}
{% set r1 = time >= nightstart %}
{% set r2 = elevation <= daystart and time < '12:00'%}
{% else %}
{% set r1 = false %}
{% set r2 = elevation <= daystart and time >= nightstart %}
{% endif %}
{% set night = r1 or r2 %}
{% set evening = not (day or night) %}
{{ evening }}
friendly_name: Evening Lights
icon_template: "{{ 'mdi:weather-sunset-down' }}"
## night segment bs
bs_light_night:
entity_id: sensor.time, binary_sensor.bs_light_day, binary_sensor.bs_light_evening
value_template: >
{% else %}
{% endif %}
{{ night }}
I’ve also thrown in the delay off timer script.
Note: you will have to create a LOT of input numbers to store the various levels
My day segments are driven by sun elevation and input datetime’s
He asked for mine but I seriously think he would be better off with yours
I also like the way you neatly avoided the gap in his timing request
Though yours will ONLY give him a brighness at the ‘switch on time’ and for it’s whole ‘on’ duration (which is where mine kinda grew from)
Nice i tried with hour, but dumb me tried now().hour() for whatever reason. In general I still prefer multiline instead of single line templates, just find it easier to read and maintain.
I wanted to ask for the gap and then just ignored it
I just provided an answer to his initial question, didn’t want to overwhelm him, as I assumed that he is a relatively new HA user.
I’m always amazed at what you (and the other usual suspects, you know which persons I’m talking about ) are doing with templates and automations and combinations of input_booleans, sensors and whatever, clever and elegant, you have my respect. When I started with home assistant, I tried some automations and at one point I got stuck and my code was getting more and more, for what I thought were really simple things. Then I discovered AppDaemon and said to myself “Screw this s***! Learn Python and do it with AppDaemon.” Ohh boy was this a good decision! Never looked back, now I’m only using automations in my Test environment (more of a “HA forum help environment” set this up just to test code snippets from people looking for help, to not spam my prod or dev environment.).
Sorry OP for spaming your post with uninteresting blabla.
Ahhhh noooooo !
I am but a simple novice trying to emulate the ‘notables’ you refer to (they also are uncomfortable with any exceptional honorifics (it just sets them up for a fall) (we all put our pant legs on, one at a time (cept for Phil and Taras )))
I just want to keep my install as ‘vanilla’ as possible and EVERYONE has to use yaml in somepart of their config. The overhead for nodered and appdaemon is horrendous.
And “IF” it can be done with native yaml, why not ?
flamingm0e (for example) is a flaming nodered zelot (no offence moe ) but each to his own
It’s one of the beauties of HA
I’ll add my appologies to the OP too
@henaa , let us know if you got what you need, even if you just mark it as solved. If you have further questions/issues we’ll see what we can do
I must say I’m a huge AppDaemon fanboy Can reload my automations without any HA restart, can reuse code, can do complex automations without any workarounds, almost no limitation, can use time travel to simulate events/automations and and and, you need to try it at some point And now that we have HACS, I can even release my apps and people don’t need to know python, just some basic YAML for the config.
