Automation with input to change service call
I am trying to make a pretty simple automation change based on a numbered input and I cannot get it to work. Appreciate any help/input, thanks!
I want the automation to call a service, and change one part of the “params” field of the “service data”.
This is the basic automation that works fine:
- alias: Clean Kitchen
    - service: vacuum.send_command
        entity_id: vacuum.xiaomi_vacuum_cleaner
        command: app_zoned_clean
        params: [[27500, 28000, 30200, 30000, 1]]
Now I want to change the last number in the params, from 1 to 5 and this is what I have tried to do:
    - alias: Clean Kitchen Times
        platform: state
        entity_id: input_number.clean_times_kitchen
          data_template:
            params: "[[27500, 28000, 30200, 30000, {{ trigger.to_state.state | int }}]]"
This is my input_number in the configuration.yaml file:
    input_number:
      clean_times_kitchen:
        initial: 1
        min: 1
        max: 5
        step: 1
The automation does trigger, but the params dont seem to work as they should. (No zone is drawn in the application like it is when the first automation is called)
Thanks!
Try:
            params: [[27500, 28000, 30200, 30000, "{{ trigger.to_state.state | int }}"]]
But even that might not work. I seem to recall trying to help someone else with this some time ago. The problem may be that the xiaomi_vacuum_cleaner code may need a number, and Jinja templates can only result in strings, even if they are string representations of numbers. But give it a try anyway.
