im trying to set up an automation that uses the PV Excess to charge my car. It should’nt too complicated - i just want to use the PV excess (e.g. of last 5 minutes) to adjust the Wallbox charging rate.
I’ve made a simple POC but i’m not sure how i could archive my goal!
to clarify - i have the following Setup:
PV Inverter from SolarEdge
Keba P30 Wallbox (X Series)
Audi PHEV also connected to HA
and all these components are working in HA.
I have the following Sensors which gives me the right values (the PV-Excess)
How could i reach the goal while not creating for every pair of Excess and Charging power to one simple Automation? I just need a simple “Case” or Else if ?!
I’m relative new to the HA scene and this is my very first Challenge.
This looks very promising, but I have one question:
Once the amps are set, your PV Excess will drop since the power will be going to the car. Wouldn’t that cause the automation to then reduce the charging current?
And what happens if your PV excess increases after the initial charging current has been set? Would it then stay at the selected value or adapt?
