Automation with Multiple Triggers and Conditions
I want to create a single automation that will turn on a switch at a specific time based on the day of the week.
E.g.
If (Mon, Tue, Wed, Thur)
   Then (Turn on @ 9:15pm)
Else If (Fri, Sat, Sun)
   Then (Turn on @ 10:30pm)
I have been playing around with the automation Trigger and Conditions and cannot find a way to accomplish this, seemingly very simple, task…
How can I accomplish this in a single automation?
I would use 2 triggers, one for each time block. Then under action I would use a choose option and split the two options, something like the following maybe:
mode: single
  - platform: time
    at: "21:15:00"
  - platform: time
    at: "22:30:00"
condition: []
  - choose:
      - conditions:
          - condition: trigger
          - condition: time
            weekday:
              - mon
              - tue
              - wed
              - thu
        sequence:
          - service: switch.turn_on
            data: {}
              entity_id: switch.your_switch
      - conditions:
          - condition: time
            weekday:
              - fri
              - sat
              - sun
        sequence:
            data: {}
There are multiple ways to do this using if_else, templates etc, but for quick and easy the above should work!
Thank you for this suggestion! I think it will work well for my use.
