I am trying to add an if/else condition to the action block of an automation. The intended function is to perform switch.turn_on service but the target entity_id will change depending on the state of a sensor.
automations.yaml
- id: '1614154379154'
alias: 'Switch: Bedroom'
description: ''
- device_id: fb42aead6bc46d9a778cfc0079312ada
domain: hue
platform: device
type: remote_button_short_release
subtype: turn_on
domain: hue
platform: device
type: remote_button_long_release
subtype: turn_on
condition: []
- service: switch.turn_on
entity_id: >
{% if is_state('sensor.lighting_mode', 'CT') %}
switch.circadian_lighting_bedroom_ct
{% else %}
switch.circadian_lighting_bedroom_xy
{% endif %}
mode: single
When using the configuration validator, I get the error
Invalid config for [automation]: not a valid value for dictionary value @ data['action'][0]['target']['entity_id']. Got None.
Does anyone have a clue what I might be doing wrong? My configuration looks like it should be valid based on the “Use Templates to Determine The Attributes” example in the documentation.
Help is appreciated! Thanks!
