Automation with Shelly 1
Hi.
I’m configurating a shelly one switch. Works great, but I’d like to execute two different automations depending on if I turn it on via the wall switch or via home assistant (mqtt). Is it possible?
Via the wall switch I want to turn on the light attached to the shelly and another light connected to a sonoff device.
Via home assistant I want to turn on only the light attached to the shelly.
With this automation there’s no way to switch on only the “livingroom_light_shelly”.
- alias: Switch on living room lights
    platform: state
    entity_id: switch.livingroom_light_shelly
    to: 'on'
   - service: switch.turn_on
        entity_id: switch.livingroom_light_sonoff
Any ideas?
shellies/<model>-<deviceid>/input/0 topic informs about state of phisical switch connected to Shelly. You have to do an automation based on changing the state of the input binary_sensor (pressing the physical switch).
I’ll try this. Thanks!!!
Do you kknow if there’s a similar topic with Tasmota firmware?
Thanks!
I don’t use Tasmota with Shellies. If you have problems with MQTT configuration try Shellies Discovery script. It supports input topic.
Thanks again!
