Hi all, I hope someone can help. Any idea why below automation is not working?
I have a tado thermostate radiotor knob with a temperature sensor. I would like to turn off my Refoss smart plug when it hits 19 degrees on that sensor, but nothing is happening…
You don’t need the attribute: setting. Leave the attribute box blank unless you are absolutely sure that the temperature is in the setting attribute of your sensor, rather than its state.
Then delete the whole automation and use this instead:
Hi Troon, Thanks the generic thermostat is indeed working now. But it did lead to a follow up question…I was expecting below settings to turn on the heater when it drops below 18 and turn off the heater when it exceeds 20, but that doesnt seem to work.
