Hey,
I bought a xiaomi switch and I want to use it in an automation.
The idea is that when I press the switch and the input boolean mode_cooking is turned off it will turn it on.
When I try that with the following automation:
- id: switch_cooking_mode_on
alias: Enable cooking mode if cooking is off
platform: mqtt
topic: 'zigbee2mqtt/xxxx'
condition:
- condition: template
value_template: '{{ "single" == trigger.payload_json.click }}'
- condition: state
entity_id: input_boolean.mode_cooking
state: off
service: input_boolean.turn_on
I get the following error when checking the config:
Configuration invalid
Invalid config for [automation]: extra keys not allowed @ data['condition'][0]['state']. Got None
not a valid value for dictionary value @ data['condition'][0]['condition']. Got None. (See /config/configuration.yaml, line xxx). Please check the docs at https://home-assistant.io/components/automation/
It goes wrong when I added the second condition, I have searched the documentation but couldn’t find template conditionals with normal
conditions. Is that correct?
And so do I need to create a switch in between?
