I’m working on a garage door opener. I want to send out a notification when the garage has been open for 5, 10, 30, and 60 minutes. So far this is working. However, I also want to stop notifications if the garage door closes. This last piece is what I’m struggling with. Is there a way to reset timing in an automation? I tried creating another automation to turn off the first, but that doesn’t work as the timer continues to work in the background.
I feel like there is a better way of doing this. Please let me know your thoughts. Thanks.
Below is my automation config (I’m using seconds instead of minutes to test):
- action:
- data:
message: Garage is open
service: notify.telegram
- delay: 00:00:05
- condition: state
entity_id: sensor.garage_status
state: Door Open
- service: notify.telegram
message: Garage has been open for 5 minutes now
- delay: 00:00:05
- condition: state
state: Door Open
message: Garage has been open for 10 minutes now
- delay: 00:00:20
- condition: state
state: Door Open
message: Garage has been open for 30 minutes now
- delay: 00:00:30
- condition: state
state: Door Open
message: Garage has been open for 1 hour now
alias: Garage door is open
condition: []
- entity_id: sensor.garage_status
platform: state
to: Door Open
Rather than set that up as one action with delays, set it up as a single automation with multiple triggers. Use the “for” attribute of the state platform. Have it trigger if door has been opened for 5 min, 10, 20…
thanks a lot @ih8gates that solved my problem. I broke it up into 4 different automations so I can send 4 different notifications. Is there a smarter way of doing this in one automation maybe?
- alias: Notifications Garage Door is Open for 5 mins
- platform: state
to: Door Open
for:
minutes: 5
- alias: Notifications Garage Door is Open for 10 mins
- platform: state
to: Door Open
for:
minutes: 10
- alias: Notifications Garage Door is Open for 30 mins
- platform: state
to: Door Open
for:
minutes: 30
- alias: Notifications Garage Door is Open for 1 hour
- platform: state
to: Door Open
for:
minutes: 60
You could probably combine things and use a template to generate the number for how long the door has been open. But then you’ll need to figure out how to do math with timestamps. Advanced stuff!
You can try this for a repeating 5 minute template trigger. It essentially test if 300 seconds is evenly divisible by the time since triggered / changed in seconds.
{{ (as_timestamp(now()) | int - (as_timestamp(states.script.chime.attributes.last_triggered ) | int )) / 300 == ((as_timestamp(now()) | int - (as_timestamp(states.script.chime.attributes.last_triggered ) | int )) / 300) | int }}
Just FYI - this is the setup I’m using (it’s in the configuration.yaml, though, not in my automations):
# Alert for Garage Door having been open for 5 minutes
alert:
garage_door_open_long:
name: Garage Door is still open!
entity_id: binary_sensor.garage_door_sensor
state: 'off' # Optional, 'on' is the default value
repeat: 5
# - 10
# - 30
# - 60
can_acknowledge: true # Optional, default is true
skip_first: true # Optional, false is the default
notifiers:
- mypushbullet
- emailfrommailgun
I’ve not played with the values I commented out - a reminder every 5min is good for me.
What I like particularly is that I can turn off the alerts when I know my garage door is open and don’t need to be reminded every 5min.
