Automation working, but not displayed
Hi!
I am facing very strange problem and would like to ask for help/advise if somebody can.
My setup is HAOS on HP server with Conbee II as zigbee coordinator.
Everything in my HAOS installation works properly - the devices are visible, automations are working - summarized OK.
But!
Previously I configured one Ikea bulb and ikea switch to operate in my room. The ikea switch is connected to the HAOS with zigbee and the lamp is also connectod to the HAOS with zigbee. No direct connection between button and bulb.
It works properly - all features - on/off, dimming, colors, everything. But I can not see the relation in the configuration. In the automation file all of other automations are there - up and running except this one. Now I am wondering where else I can try to find something. The log file shows “button pressed” and “Lamp switched on/off etc.” But there is no rule for this action!!!
Probably in he past I configured everything in older release of the HAOS and somewhere during the updates of the HA, core, modules etc the configuration rule becomes hidden somewhere.
I will highly appreciate any advice or help to solve the problem.
What is the zigbee tool you are using? Zigbee2mqtt or zha?
You can pair devices direct with such a tool and you don’t need an automation
Thank you. I am using ZHA.
Probably I used some “binding” feature in the past but I cant remember. It was few years ago.
Is there a way to check these bindings?
You should be able to see the binding in zha
