I’m pretty new to HA,
but adding sensors and switches is easy for me and I add a lot for someone who just started.
I can control and see a lot at this point and im just running for one week.
But the one thing that doesnt work is automations. I have no clue why. I made one as simple as possible and still it doesnt work.
Because im new i probbly do something simple wrong, but i cant figure it out.
I added some automations in the GUI and one in de config file for testing.
In this case i like to switch on a light when the door go’s open.
My configuration.yaml that should include this.
things i tried:
change closed and open to on and off.
remove “old” from “automation old:”
hash out the rule “#automation: !include automations.yaml”
tried differend sensors.
ofcourse i restarted home assistant after every change.
The check also tels me that the config is oke.
I can also see that HA is picking up the sensor when it open’s or closes.
and i can manualy toggle the light(s).
anything would be helpful. if there is more info nessesary from my side i’m happy to share it.
As well as your config file you should have an automations.yaml file, as you have this:
Put your automation in that file, like this (note the other changes I made to the trigger)
- alias: simple automatisering
initial_state: true
description: ''
- entity_id: binary_sensor.door_window_sensor_158d00044dde74
from: 'off' # binary sensors states are only ever 'on' or 'off' no matter how they are displayed n the frontend.
platform: state
to: 'on'
condition: []
- brightness_pct: 10
device_id: b231a79674544012ae92b94afabd71bc
domain: light
entity_id: light.60600011ecfabc3c8efc
type: turn_on
Do not put automation: in this file. Just start each seperate automation with - alias:
I don’t use device automations so can not comment on the validity of your action block.
After making changes and saving, do a configuration check. If that passes you can use “Reload Automations” instead or restarting.
Use this. Just check status of your light in developer
- id: turn_light_on_if_door_opened
alias: Turn light on if door opened
initial_state: 'on'
platform: state
to: 'on'## or 'open'
##check if light is off
condition:
- condition: template
value_template: >
{{ is_state('light.60600011ecfabc3c8efc', 'off')}}
- service: light.turn_on
so that the UI editor writes into automations.yaml (currently empty) and I keep all of my hand-written automations in automations/*.yaml, safe from the editor’s comment-deletion and re-ordering of declarations into a stupid order .
In that case it’s probably only the trigger that needs fixing:
platform: state
to: 'on'
I made some automations by now.
the part ‘on’ / ‘off’ was my problem i think.
i gues i need to figure out for every sensor and entity wat the possible states are.
im also gonna use the recomandation from Troon.
I think i will mess some automations in the future
And this will give me a easy option to give me some hobby space.
one’s i got this all figured out the realy automations are starting
automatic start the vacuum when nobody’s @home. turn some lights off when everybody is gone.
but this will be things for a rainy sunday.
haha yeah that would be a problem.
but i think there is a DND inside the vacuum.
or i make a condition where it only works between sunrise and sunset… or something.
