Automations drifting off time, and increasing
Hi team
my first post overhere, running HA on a VM with supervisor etc. All my automation are off sync, which means they are hours to late. Its for all of them, enabling the Sonos speaker (power plug) is hours to late but also the notification for the garbage.
It has worked for several years without an issue, is there any way you are able to help me troubleshoot this?
For example the screenshot below, notice the time stamps…
Reinstalled my VM and restored a snapshot. Situation is the same, first automation fires 1,5 minute to late. When running a debug automation few hours later its already 3 minutes drifted off.
While the log time is 100% correct…
This one should run 21:00:00 sharp…
alias: Debugging for timing
description: ''
  - platform: time
    at: '21:00'
condition: []
  - service: light.turn_off
      area_id: 1571542997a34691b652252b05f47430
mode: single
Problem found, it was due tot a wrong configuration in the ESX NTP service. After that was corrected the automations runs sharp on time.
If you don’t mind, may I ask how did you correct the ESX NTP? A few users here also experience the same error. Maybe by explaining here how you solve it will help others facing the same issue.
After explaining your solution, please mark your own answer as the SOLUTION.
Thank you.
Sure here it is, don’t forget to start the service.
