Automations failing to save, Will buy some one a virtual coffee for some help
2 weeks into HA and seem I can’t save automations getting a message which says the following
Ive looked at everything from the config to logs and can’t figure out why I can’t save any automations
any help would be greatly appreciated
Did you do what the error message asked you to do? Go to Developer Tools → YAML and check the configuration.
You will most probably get an error message which will tell you where exactly the problem is.
