Since a few weeks my automations never work after a HA restart. I created a script with a button to manually restart all automations. It’s a fix, but not a solution.
Nobody will have any if you don’t show your automations and define what “doesn’t work” means to you.
Crystal balls are even harder to find than RPI4 those days…
Since some time, probably after an update, my automations which are based on switches do not work anymore after reboot.
I can see in the automation view that when I click a button of a switch the text triggered and I can run the automation manually and the Action works but not via the switch / button (zigbee).
When I change something in the automation and save it, then it works until I restart Ha and then it does not work anymore
Did someone else have found a solution for this exact problem? I also have this when triggering automations from Switches. After a reboot the automations with switches stop working until i change something in this automation and save it. Then it will work until the next reboot and it is broken.
I’m looking at the restart of the automations work-a-round. I haven’t tried this yet but it would temp.solve this problem for me as well.
I have tried the work-a-round bij disabling and enabling the automations after a Home assistant reboot. This kinda works, but not always reliable.
I’ve observed that the automations give errors complaining about that the device did not respond.
Stopped because an error was encountered at August 4, 2023 at 11:47:10 PM (runtime: 15.33 seconds)
Failed to send request: device did not respond
This happens often, resulting in the automations to “lock and wait for timeout”. The automations run for about 15 seconds…
If the automations work correctly, they all run in about 0.36 seconds.
To be sure, i’ve checked all my zigbee/wifi devices. They have all great signal quality and respond immediately when triggered manually. They never fail manually. Just when using a switch automation, it’s like a mess…
I’ve the same issue. After reboot I have to open the automation and do a trigger. After that they will work until restart. Does anyone found a solution?
I don’t have a solution but I’m facing the same issue, so next time I’ll try the script. I’m using the Container version, Core 2023.11.2, Frontend 20231030.2.
This is how it happened for me: I’m using Conbee II with deCONZ for all zigbee devices. Last time deCONZ crashed and I had to reboot the Pi. I have started the deCONZ container after HA was already running. All the devices and entities were there, and I could control the lamps using the dashboard. The switches even registered the button presses. It was just the automations that were not triggering.
First time this happened to me, I have recreated triggers for all automations. This time I realized that they start working even if I just disable/enable them one by one (but I was hoping to see a way to do this for all of them at once). So I’m happy to see there’s this script to try next time.
I am expriencing the same issue. Automations trigger but the actions do not work after a restart. Recreating the action verbatim has helped, I’ll try disable/enable next time. This seems a prevalent issue, it would be great for this kind of basic functionality to become solid.
I too have the same problem but for me this is happening for a long time already.
I am running the OVA image on my Synology and I am also using Conbee II USB stick with deconz add on.
Every time I restart the VM all of the buttons stopped working. At first I have recreated automations. Then I also noticed I just had to change and save the automation to make it work again. And then I noticed deactivating and activating also did the trick sometimes (not every time).
What’s really weird is when I edit the automation and then press the button I it even says that the button was pressed but nothing happens. When I click run automation from the menu everything works.
So basically the same problem everybody else has.
Additional information:
When I restart the VM I have to manually go into settings and attach the USB stick after starting the VM. Every restart it gets disconnected. And I also have set the deconz addon to manual start because I think I had some issues when the USB stick was not connected when the stick wasn’t already connected.
I’d be really nice if someone had some insights into why it’s not working.
I am experiencing the very same issue. Yesterday we had some trouble with our internet connection and I restarted the Home Assistant Docker container on our Synology DS220+. After the restart the ZHA intergration (SkyConnect) failed to setup. I physically disconnected the SkyConnect USB stick and connected it again and the intergration was working again.
Nonetheless, none of our Ikea wall switches worked. The solution for now seems to be this for us:
Go to automations → open an automation where the switch isn’t working → Disable one action → Save → Enable that action again → Save again. Now the button/switch on the wall is working again. I restarted Home Assistant in the UI to see if it’s still working after a restart and everything is still working fine.
I don’t dare to restart the container to test if it’s still working after that since this is taking a lot of time.
I guess it’s time to switch from a Docker Container to the Home Assistant Yellow…
Have the same problem since months.
I put so many hours into this, including complete reinstall and what not.
Automations with zigbee/deconz just stop working for no reason.
Adding something to it (that does not do anything) and SAVE it, get it back working.
After reboot: Not working again. Delete the above dummy entry and SAVE again - it’s working till next reboot.
Looks like it’s getting worse every with update.
It’s just not reliable on so many levels now.
Homeassistant once was really a good working software, those days are over, I guess. Sad.
The fastest workaround I found, if you have a ton of automations like me, is to go to the “automations-page” and disable all zigbee/deconz containing automations. Reload the page and activate them again.
Until the next reboot, though …
Well I have switched from running Home Assistant in a docker container on our Synology NAS with a SkyConnect stick to a Home Assistant Yellow device and I haven’t had any issues anymore! It’s way more expensive but it’s worth every penny to me. I have been solving many problems that took many hours of my time while using Home Assistant in a docker container and since we have made the switch to the HA Yellow it’s been a trouble free experience for over a month now!
I just had the same issue pop up with a simple script I have to turn the lights on if a person is detected after dark.
I am fairly new to automations/scripts in Home Assistant. I have a simple script that will turn on the front door light for 3 minutes if a person is detected and it is dark outside. I only set the script up a few days ago and it worked perfectly since I did. However, I did an update to Home Assistant (OVA on an old box in the basement) and had to shut the server down for unrelated maintenance. After rebooting the server and ensuring that the VM was up and running, my wife decided to test the automation as she had not seen it work since I set it up. Imagine her disappointment when she went outside and nothing happened!
I investigated and found that the camera the script should call was correctly reporting whether there was a person present and if it was dark outside. I manually triggered the light in question from the HA app and via the Lutron switch that controls the light, all no problem. When I reviewed the script traces, I found no entries despite the camera showing that there was a person present and it was dark out.
After manually triggering the script by selecting “run” on the 3 dot menu, the script seems to work without issue again.
Script:
alias: Front Door Light Person Detection After Dark
sequence:
- wait_for_trigger:
- type: turned_on
platform: device
device_id: [id of person detection sensor from camera]
entity_id: [id of person detection sensor from camera]
domain: binary_sensor
- type: turned_on
platform: device
device_id: [id of darkness sensor from camera]
entity_id: [id of darkness sensor from camera]
- service: light.turn_on
metadata: {}
brightness_pct: 100
device_id: [id of Lutron Switch]
- delay:
hours: 0
minutes: 3
seconds: 0
milliseconds: 0
- service: light.turn_off
metadata: {}
data: {}
description: ''
icon: mdi:lightbulb-on
mode: restart
Related information from the “Step Details” section of “Traces” from the successful run of the script after manually triggering the script (note that there were no entries in this section before manually triggering the script):
As stated above, this is the OVA which is currently running in VirtualBox on an Ubuntu host.
It would be really nice to figure out what is going on here. If scripts and automations are not able to be relied upon after an update or a system reboot, I’m not sure how much trust I can put into automating systems in my home. The unreliability will also dramatically reduce the WAF.
I just wanted to respond that I think that the I haven’t seen the issue in a while, maybe after upgrading, but I’m not 100% sure (the uptime is now 100+ days so I haven’t rebooted in a while). I’m currently running Core 2024.7.2 / Frontend 20240710.0 (this is the container version running on a very low-end Orange Pi One / Armbian). If it happens again, I’ll post an update.
