I recently upgraded my Hassbian installation on a Pi3 to the newest version 0.44.1 and upgrade the OS (sudo apt-get && sudo apt-get dist-upgrade). Raspberry firmware is version 4.3.24 (rpi-update).
Since then I get all kinds of errors in my log. If I exclude all automations, then HA starts without problems, but as soon as I include automations then the errors are occurring again.
The following errors have been logged this session:
2017-05-11 22:19:16 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved Traceback (most recent call last): File "/usr/lib/python3.4/asyncio/tasks.py", line 233, in _step result = coro.throw(exc) File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/setup.py", line 60, in async_setup_component return (yield from task) File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__ yield self # This tells Task to wait for completion. File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup value = future.result() File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result raise self._exception File "/usr/lib/python3.4/asyncio/tasks.py", line 237, in _step result = next(coro) File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/setup.py", line 155, in _async_setup_component conf_util.async_process_component_config(hass, config, domain) File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/config.py", line 548, in async_process_component_config p_validated = component.PLATFORM_SCHEMA(p_config) File "/srv/homeassistant/lib/python3.4/site-packages/voluptuous/schema_builder.py", line 221, in __call__ return self._compiled([], data) File "/srv/homeassistant/lib/python3.4/site-packages/voluptuous/schema_builder.py", line 538, in validate_dict return base_validate(path, iteritems(data), out) File "/srv/homeassistant/lib/python3.4/site-packages/voluptuous/schema_builder.py", line 315, in validate_mapping cval = cvalue(key_path, value) File "/srv/homeassistant/lib/python3.4/site-packages/voluptuous/schema_builder.py", line 716, in validate_callable return schema(data) File "/srv/homeassistant/lib/python3.4/site-packages/voluptuous/validators.py", line 262, in __call__ v = schema(v) File "/srv/homeassistant/lib/python3.4/site-packages/voluptuous/schema_builder.py", line 221, in __call__ return self._compiled([], data) File "/srv/homeassistant/lib/python3.4/site-packages/voluptuous/schema_builder.py", line 575, in validate_sequence cval = validate(index_path, value) File "/srv/homeassistant/lib/python3.4/site-packages/voluptuous/schema_builder.py", line 716, in validate_callable return schema(data) File "/srv/homeassistant/lib/python3.4/site-packages/voluptuous/validators.py", line 224, in __call__ return schema(v) File "/srv/homeassistant/lib/python3.4/site-packages/voluptuous/schema_builder.py", line 221, in __call__ return self._compiled([], data) File "/srv/homeassistant/lib/python3.4/site-packages/voluptuous/schema_builder.py", line 716, in validate_callable return schema(data) File "/srv/homeassistant/lib/python3.4/site-packages/voluptuous/validators.py", line 262, in __call__ v = schema(v) File "/srv/homeassistant/lib/python3.4/site-packages/voluptuous/schema_builder.py", line 221, in __call__ return self._compiled([], data) File "/srv/homeassistant/lib/python3.4/site-packages/voluptuous/schema_builder.py", line 716, in validate_callable return schema(data) File "/srv/homeassistant/lib/python3.4/site-packages/voluptuous/schema_builder.py", line 221, in __call__ return self._compiled([], data) File "/srv/homeassistant/lib/python3.4/site-packages/voluptuous/schema_builder.py", line 538, in validate_dict return base_validate(path, iteritems(data), out) File "/srv/homeassistant/lib/python3.4/site-packages/voluptuous/schema_builder.py", line 315, in validate_mapping cval = cvalue(key_path, value) File "/srv/homeassistant/lib/python3.4/site-packages/voluptuous/schema_builder.py", line 716, in validate_callable return schema(data) File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/config_validation.py", line 222, in service if valid_entity_id(value): File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/core.py", line 66, in valid_entity_id return ENTITY_ID_PATTERN.match(entity_id) is not None TypeError: expected string or buffer
