Does anyone have any ideas why a week after adding the following automation it should suddenly be rejected? I set it up, it does what I want. I have rebooted the controller several times. Today I tweaked a sensor snippet in sensors.yaml and when I reload HA (Hassbian on a Raspberry Pi 3) I had the following error:
Nov 19 21:32:14 hassbian2 hass[813]: 2019-11-19 21:32:14 ERROR (SyncWorker_0) [homeassistant.util.yaml.loader] while parsing a flow mapping
Nov 19 21:32:14 hassbian2 hass[813]: in "/home/homeassistant/.homeassistant/automations.yaml", line 624, column 7
Nov 19 21:32:14 hassbian2 hass[813]: expected ',' or '}', but got '<scalar>'
Nov 19 21:32:14 hassbian2 hass[813]: in "/home/homeassistant/.homeassistant/automations.yaml", line 628, column 7
Nov 19 21:32:14 hassbian2 hass[813]: 2019-11-19 21:32:14 ERROR (MainThread) [homeassistant.bootstrap] Error loading /home/homeassistant/.homeassistant/configuration.yaml: while parsing a flow mapping
Thanks very much @anon43302295 for your speedy response - I must have knocked off the comma without realising it. And yes @Mutt you are correct the # was for indication purposes only.
Interestingly with the comma restored the error mentioned above goes away, but I noticed another error message which has not stopped HA reloading. It states:
I had not realised one could not have more than one parameter changed at a time and when I tested this originally I only checked it had changed the parameter 6 and not the parameter 7.
I have split the parameters into two - service: sections and now have no error messages.
You still appear to be missing the comma off the second value line, unless you knocked that one off at the same time ?
I also, from my experience with these sirens, think you should have a small delay following any parameter setting to allow for comms propagation. 1 second works for me.
I also only use the alarm mode (not the alarm mode) as I switch the siren on and off, that way I only ever send 1 parameter, with 1 sec and then sound the siren.
Did you manage to get this to work without a delay ?
Your alias for this seems a bit astray from what it does too
Apologies for the delay in replying, life getting in the way.
Thank you both for your observations and help. @Mutt, the title and the trigger are both a bit random. I was playing with different bits of automation ideas and out of laziness didnāt change everything before publishing the coding on this forum.
I have managed to get the alarm to change from the Doorbell music setting to the Alarm music setting (Parameter 7) and change the Alarm music (Parameter 5) using the following:
- alias: 'Set buzzer to Volume to 1'
platform: state
entity_id: input_boolean.heater_controlled_by_thermostat
to: 'on'
- service: zwave.set_config_parameter
node_id: 5
parameter: 7
value: 'Alarm music'
node_id: 5
parameter: 5
value: 'William Tell'
The setting before I triggered this automation was default Door bell music and the Alarm music was set to āEvacuationā. Before the automation was triggered the alarm played the music on the Door bell music. After the automation was triggered it played William Tell.
I havenāt tried setting up the automation to first change the parameters and then trigger the alarm, but if necessary I will put in the 1 second delay. Thank you for the tip.
And thank you @freshcoast. I used the date_template because that was in the example I came across. As you can see, I have removed the template bits and it runs fine.
Now I have got this concept working I will brush up the title and trigger!
Thanks very much to you both.
Yes, as was mine, but I went through the zwave manager and changed the parameter defaults
I donāt have to worry about most of that stuff any more, I just change the tune.
