Autostart on macOS
Tags: #<Tag:0x00007f7398e6f768>
:warning: This guide has been migrated from our website and might be outdated. Feel free to edit this guide to update it, and to remove this message after that.
Setting up Home Assistant to run as a background service is simple; macOS will start Home Assistant after the system has booted, the user has logged in, and make sure it’s always running.
To get Home Assistant installed as a background service, run:
$ hass --script macos install
Home Assistant has been installed.         Open it here: http://localhost:8123
Home Assistant will log to ~/Library/Logs/homeassistant.log
Configuration is kept in ~/.homeassistant
To uninstall the service, run:
$ hass --script macos uninstall
Home Assistant has been uninstalled.
Note:
automake is required for hass to start. If you are missing this on your system, you can install this by running:
brew install autoconf
