You can get all the bulbs and their states via get and set all stuff via post. Currently I have it accessible via HA Bridge, but it be cool to see it in Home Assistant!
I looked into the code for Yeelight, but it seems like I have to learn a lot of Python to write it myself
How is your current setup? I think it would be great to have a decent “component” for the Avea bulb, but the workaround seems okay, too. However one has to run ha-bridge as well as avea-server to be able to route the requests to ha-bridge to a web interface? Sounds like I would have to have another rpi running for this setup.
Feedback is welcome, I will work now on the component for hass
You should be ready to control you avea via command line, for example change the brightness with curl -d "brightness=0" -X POST http://hassio.local:3000/api/bulbs/fge87efgfg7f
It took me quite a long time but I wrote a “real” Avea component for Ha without the need of any server/addon: https://github.com/pattyland/hass_avea
Thanks for your answer! I have no “avea” word in logs at all, but I can see my bulb in bluetooth devices around on my phone. Should it be displayed in “Integrations” section?
Hm, I don’t know if the Bulb will work without being configured in the app. That’s my only known way to set a name for example
Are you using Home Assistant OS?
If you can, you should try using the library I’m using to control avea bulbs: https://pypi.org/project/avea/
(I’m not the author of it, I just wrote the integration for Home Assistant)
Hi! Thanks for your support. I really looked in the wrong place. But later I found my bulb in entity list with id “light.avea_bulb_1”. I’m sure it should be specified in the configuration section on page https://www.home-assistant.io/integrations/avea.
I’m having trouble with my Avea bulb. It has functioned well before, so we know it has worked. t also shows up in the list of bluetooth devices when I look into bluetoothctl on the command line. Here is the error log:
Logger: homeassistant.components.light
Source: helpers/entity.py:887
Integration: Light ([documentation](https://www.home-assistant.io/integrations/light), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+light%22))
First occurred: 1:23:53 PM (2 occurrences)
Last logged: 1:23:53 PM
* Error adding entities for domain light with platform avea
* Error while setting up avea platform for light
Traceback (most recent call last): File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 382, in async_add_entities await asyncio.gather(*tasks) File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 587, in _async_add_entity await entity.add_to_platform_finish() File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 698, in add_to_platform_finish self.async_write_ha_state() File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 464, in async_write_ha_state self._async_write_ha_state() File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 498, in _async_write_ha_state state = self._stringify_state() File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 470, in _stringify_state state = self.state File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 882, in state return STATE_ON if self.is_on else STATE_OFF File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 887, in is_on return self._attr_is_on AttributeError: 'AveaLight' object has no attribute '_attr_is_on'
Any ideas? I’m on the newest version of HA. Did a breaking change get introduced?
