I’ve been working on a plugin to control an AVGear TMX44PRO AVK, which is a HDMI/HdBT matrix switch.
I’ve got it working reliably - for my use cases, and wanted to share to see if anyone else has the same devices (or device family) to help with testing.
The HA plugin is here: hass-avgear-matrix and there is a library that I’ve created which has the core smarts in it: hdmimatrix
Happy to get feedback on it, and hopefully it helps someone.
Hello!
That’s a great contribution! Sharing your hass‑avgear‑matrix plugin along with the hdmimatrix library will definitely help others who use the AVGear TMX44PRO or similar HDMI/HdBT matrix switches. Having it working reliably for your use cases is already a strong start, and community testing across different setups will be valuable for refining compatibility and catching edge cases.
If you’d like broader feedback, you could highlight specific areas where testers should focus (e.g., switching speed, error handling, integration with HA automations). That way, anyone with the same device family can give you targeted input and help validate the plugin’s robustness.
Hi Brandon,
The AC-MX-44X looks to be from AVPro not AVGear, but after a quick look at the manual it’s reasonably similar. If you are willing and able to do some testing then I’m happy to have a look at it when I get back to my desk in a week or so.
Let me know,
Mark
