is it possible to add the “boost” function?
This has recently been added to the library add adaptive heating and boost support to thermostats by sebuer · Pull Request #97 · hthiery/python-fritzhome · GitHub and the new library version will be picked soon in HA with Bump python-fritzhome to 0.6.11 by mib1185 · Pull Request #115904 · home-assistant/core · GitHub, but there is still some work left to make the feature usable in HA
Hi @stephanschleichstr13
This feature should be available since HA core 2024.5 - so do you mind to mark it as solved?
thanks
Closing as this was implemented.
